The second uRADMonitor unit in Arizona just went online. Unlike the other unit to the North – that is run at higher altitude and shows increased readings, the new unit measures an average of 11.3CPM (on a SI29BG tube), approximated for the background radiation to a dose of 0.11uSv/h, not unlike what it has seen during the initial tests in Timisoara:
The data is available online, here.
