Stable Power Module is professionally designed with power IC 5V-5A to provide stable power for Companion computer as well as peripheral devices. It also has a built-in Serial port for connecting Companion computer and flight control. All connector in Stable Power Module is dronecode standard (JST GH and Molex CLIK-Mate).Technical detail:🎖 Dimension: 60 x 35 x 15 mm🎖 Weight: 21gram🎖 Power Input: 7 to 36V power input (CLIK-Mate 2.00mm)🎖 Power Output: 5V/5A🎖 Features:+ Serial port (JST-GH)+ Reverse voltage protection+ Resist fluctuated, noise of electric power+ Green Led Indicator Power 🎖 Compatible: Compatible with all companion computer which have Rasp Pi pinout (2x20 2.54mm)+ All Raspberry Pi models (Rasp Pi Zero W, Rasp Pi 3B/B+, …)+ ODROID-C2More detail: https://store.xbstation.com
