The schematic for version 3 has been completed and added to the project files. The microcontroller has been removed from the circuit along with indications by different blinking patterns; instead two new LEDs off different colors have been added to indicate when the flashlight needs to be charged and when the flashlight is done charging. A USB connection detector has also been added so that none of the main LEDs can be on while the flashlight is plugged in.
schuyler4
