Fully 3D-printable turntable
A turntable wich you can fully 3D-print, no extra parts needed!
It can be used to make beautiful cinematic shots of objects but it can also be used as a rig to make photos for photogrammetry software so you can 3D-scan objects.
The large black 'slide bearing' is printed in one peace and is free to move the moment it comes from the printbed. The print in place of moving objects adds to the simplicity of the build. The turntable is designed to be snap fitted without the need for glue, but depending on your printer, some glue might be a good idea to keep parts at their place.
Once the turntable is fully assembled, it might be hard to rotate it. I used some fine machine oil to lubricate all the parts and just turned it a lot so some wear and tear could accur wich helps with the smoothness. Once lubricated it turns very smooth. (of course not as smooth as if you were to use a bearing but pretty smooth for something wich is completely 3D-printed).
A turntable which you can fully 3D-print, no extra parts needed!
The large black 'slide bearing' is printed in one peace and is free to move the moment it comes from the print bed. The print in place of moving objects adds to the simplicity of the build. The turntable is designed to be snap fitted without the need for glue, but depending on your printer, some glue might be a good idea to keep parts at their place.
The handle attaches to the main drive shaft with an M10 tread which is directly printed onto it. For me this worked great but I can imagine this could be a problem for some printers so I might have to find a solution for this.
Once the turntable is fully assembled, it might be hard to rotate it. I used some fine machine oil to lubricate all the parts and just turned it a lot so some wear and tear could occur which helps with the smoothness. Once lubricated it turns very smooth. (of course not as smooth as if you were to use a bearing but pretty smooth for something which is completely 3D-printed).
All parts need to be very clean, no brims, rafts or supports can be attached or the thing will jam.
I added a white platform template to the files (pdf) which can be printed and cut out with scissors. the diameter of the circle is 10 mm wider than the platform.
STL and Fusion 360 source files can be found here: https://bbprojects.technology/collections/stl-fusion-360-source-files/products/fully-3d-printable-turntable-files
link to the video:
Turntable white platform template.pdf
a template for a white surface for the turntable
Adobe Portable Document Format - 131.11 kB - 07/01/2019 at 16:51
Preview
View project log
Josh Cole wrote 07/09/2019 at 19:03 • point
Thank you for sharing this! Your video is easy to digest and a really great example of clever 3d design.
Brian Brocken wrote 07/13/2019 at 22:58 • point
Thank you very much Josh! ;-)
Tom Nardi wrote 07/03/2019 at 03:15 • point
This is brilliant. Didn't realize the turntable would be print in place until I watched the video. Really cuts down on the part count.
Seems like this could be adapted to use a small stepper motor as well, would make for some very smooth videos/scans. I also wonder if the base plate could be perhaps a grid instead of a solid to cut town on print time and material, though reducing surface area doesn't always work out like that because of the perimeters.
Brian Brocken wrote 07/04/2019 at 21:13 • point
Thanks Tom, A grid patern for the plate sounds like a good idea, i'll look into it ;-)
Brian Brocken wrote 11/05/2019 at 21:07 • point
Hello Tom, I added an Arduino and stepper motor to the turntable. It is now able to take photos 360 degrees around an object which can be converted into a 3D-model using a photogrammetry program. You can check it out here: https://hackaday.io/project/168301-arduino-controlled-photogrammetry-3d-scanner
