Rev2 boards have arrived. They are SMD assembled by Elecrow. Quality is excellent as usual. They are labeled rev 2.1 for tracking purpose as I had to make a small change after the quote with the 2.0 data files.
Differences in a nutshell:
- Boards a longer to give access to the bypass jumper when a Feather is plugged in from the top.
- Shunt have an improve power rating.
- The high current range shunt is now 50mOhm to give a current range from 6.4A to 200uA.
- Banana jacks have a solder tab on the bottom for a lower resistance connection.
And this is how to board looks like with SMD components only:
MagicWolfi
