Soldering success, plug-in failure. Starting on software
A project log for free-u2f
a super cheap universal second factor token
dhruv-gramopadhyeDhruv Gramopadhye • 12/25/2019 at 23:44•0 Comments
I successfully hand soldered all the parts, including the SOIC ch554
After plugging the device in to a USB port, the chip caught some part of the metal chassis for the USB connector and ended up getting ripped out: pins bent and all.
I decided to switch to writing the software with the development boards that I had purchased earlier. I'll likely do a redesign of the hardware.
Attached is a photo of the carnage. Unfortunately I have no "before" picture.
Maybe if I decide to stay with this design, I'll go with an even thinner PCB. The thickness of the PCB combined with the thickness of the chip was too tight a fit I guess, even though I did the math and the whole thing should have still made it in.
