New wire feeding gears assembly is ready. Using welder machine feeder gear. It's incredible, works like a charm. I will share the overall progress tomorrow.
A project log for Precise Wire Bending Machine
Open-source wire bending CNC machine for wires at 1mm and less in diameter.
Awesome. Glad the wire-feeder "bearings" work as expected. It's always good to look for existing technology which is proven to work for an given application!
