I wired up the Pi to the ADXL345 and tested it and tested the code. It seemed to work fine. The Pi needed the I2C interface to be on preceding a reboot. After that I made a few modifications
import time
# Import the ADXL345 module.
import Adafruit_ADXL345
# Create an ADXL345 instance.
accel = Adafruit_ADXL345.ADXL345()
I used the above modules.
while True:
# Read the X, Y, Z axis acceleration values
x, y, z = accel.read()
if x > 500 or y > 500 or z > 500: #500 is the number that the values go above in all my crash tests
print('crash alert')
# Wait half a second and repeat.
time.sleep(0.25)
This is the code I used.
The output was the words "crash alert" showing up when I shake the ADXL345 module.
This was detected because after testing I found that in which ever angle you shake it, the X, Y, or Z value went above 500. When an actual crash happens, the entire thing would shake the same way. So I used this method to get the crash alert.
