The USB battery showed up today and I dug up an IMU from my parts bin (I knew it was around here somewhere!) so the robot is parts-complete today. I've done none of the wiring yet, but this is a good start. I managed to get everything on the chassis, which was no small feat figuring out where and how to mount things; I really wanted to make sure the IMU would be oriented usefully (X-forward), but it didn't quite work out that way, so I have to remember that it's mounted backwards (e.g. positive X to the rear).
![](https://cdn.hackaday.io/images/2177921562365235240.jpg)
Not a huge deal. Here is an ordered list of initial work:
Milestone 1: movement/somatic
- Goal: coherent motion
- The four drive motor somatic processes
- The motor part of the movement cognitive process
Milestone 2: movement/sensory
- Goal: sense of direction
- IMU sensory process
- Add IMU into the movement cognitive process fusion
Milestone 3: crash stop
- Goal: don’t try to keep going if the robot can’t keep moving
- Lidar sensory process
- Add lidar into movement fusion
- Add basic crash stop into movement - don’t service requests to go forward if the robot can’t
Research further work
- What does mapping look like with a single lidar?
- How does proprioception work?
- How does navigation work?
So the first thing to do will be to wire up the motors, make sure I can talk to the motor hat, and all that. It may turn out that the motors all have to be set at the same time with the hat, so I might have to make those four processes a single process.
