https://github.com/speedcontrols/ac_sc_grinder
One more rework:
- Ported to STM32F0 family (with limited hardware multiplication and no division).
- Significantly reduced RAM demands.
- Added HALs for new boards.
- Open triac with short pulses.
- Fixed max possible speed.
- Other minor changes.
Now firmware can fit into any MCU with 4K RAM & 32K flash. Our choice is STM32F042F6P6 - because it can be flashed by USB without ST-Llink.
Also, final schematic was simplified again, and routed for actual grinder models. Here is temporary link: https://easyeda.com/speed/ac-speed-control-v2. It was not tested yet, but i already ordered PCB and components, to check how i is. As soon as i works, i will update project docs.
What is changed (except MCU), if compare with dev board?
- Control triac via capacitor, instead of make negative MCU power. More accessible and cheap components.
- Changed step-down chip to LNK3204, because LCSC discontinued MP157.
So, optocouple with snubber network was removed in more elegant way. The only limitation - have to use 10ma triacs. But that's ok for expected kinds of use.
