We obtained the following aluminum profile(Code REH8253) from a chinese manufacturer www.robustcasing.com:
Due to the sliding action and play within the enclosure, the copper was pulled back from the board edge to accommodate this movement.
PCB with copper pulled back
Front side
Back side
PCB layout on 4 layer board.
Board specifications: 4 layer FR4 1.6mm thickness, ROHS, 1/1oz, ENIG surface finish, Green Solder Mask, White silkscreen legend color.
Top layer
Inner layer 2
Inner layer 3
Bottom layer
3D rendered PCB views right from Kicad
With regard to the 2D thermal array sensor add on:
Board specifications: 2 layer FR4 1.6mm , ROHS, 1/1oz, HASL surface finish, Green Solder Mask, White silkscreen legend color.
Top layer
Bottom layer
