The ultimate add-on for your prusa MK3(S)
Standard Tesselated Geometry - 30.36 kB - 07/13/2019 at 22:42
Zip Archive - 165.28 kB - 07/13/2019 at 12:12
These are al the parts you need.You have to buy a raspberry pi 3 without 40 pin connector or must cut all pins.
At first add raspberry pi with short bolts 3mm onto the bottom plate.(don't forget to cut the pins (I did it afterwards)
You have to add the two supports first and place the lcd board, after that you can screw the bottom plate onto it.
Finally plug in the power mini usb and at the top (I screwed it with 2 screws afterwards)
>This is the final result, I'm very happy with it!
View project log
Bob Recny
fhlipZero
Erland Lewin
Rob Crouthamel
Yes, delete it Cancel
You are about to report the project "PRUSA ADD-ON", please tell us the reason.
