I pushed some small alterations I made during construction back into the repo, there was some cosmetic tweaking to the thumbscrew and slight thinning of the wheels to allow them to fit the smallest drum settings (I made my drums a little tight after gluing pt 1 & 2).
The new files also correctly order the F/S indicator for neutron speed and extend the wheel C arms to give the read-line a little more room against the o-ring.
Everything has also been cross-posted to thingiverse.
Jeremy Ruhland
