I made a 4-bend prototype with resistors 3 Mega, 2 Mega, 1 Mega, 750k ohms.
I put the wire and connected resistors in vinyl tubing of 1/4 inch outside diameter , 0.170 inch inside diameter.
It worked!
Unfortunately, it did not work in a consistent manner because the wire connections would also bend and get out of place.
The wire connection is not reliable; therefore, I will use very small normally-closed momentary push button switches since those achieve the same function as the 2 wires touching.
