I made a calibration program using Arduino that uses serial to make the arduino choose to do calibration or read values.
Code:
The calibration fixed problems caused by error between actual output voltage and expected output voltage.
Calibration is a step in the right direction.
However, improvements need to be made to the calibration program to fix sensing multiple bends.
The assumption that only 3 individual sections need to be calibrated since multiple bends are just a linear combination of the values of 3 individual sections is not working very well.
The program needs to spend more time finding the max value output when a complete bend is made.
Pablo Antonio Camacho Jr.
