MAJOR UPDATE!!!
A project log for LEGO Saturn V and Lunar Module Come to Life
Add some interactivity to the LEGO Apollo sets! Includes exhaust plumes, audio, a countdown timer and warning lights.
ben-brooksBen Brooks 11/04/2024 at 20:370 Comments
Recently I decided to make a major update to this project, with the end result essentially being the same but all of the components and code being updated/replaced.
Why you might ask? Partly just-because, but also largely because my son has gotten old enough to be a big fan of LEGO and space (and I happened to have bought a second Saturn V a long time ago), so it made sense to redo mine and then have an easier way to duplicate it for him (as well as a variation for his younger sister). Major changes include:
I've updated the Thingiverse link with the new 3D models in case anyone wants to use them as well as uploaded the KiCAD files for the PCB. Here's the ESPHome YAML (mostly-done, but still a bit of a work-in-progress):
esphome:
  friendly_name: LEGO Apollo 11
esp32:
  board: esp32dev
  framework:
    type: arduino
#    type: esp-idf
# Enable logging
logger:
# Enable Home Assistant API
api:
  encryption:
    key: "xxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxx"
ota:
  - platform: esphome
    password: "xxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxx"
wifi:
  ssid: !secret wifi_ssid
  password: !secret wifi_password
  # Enable fallback hotspot (captive portal) in case wifi connection fails
  ap:
    ssid: "Lego-Apollo-11 Fallback Hotspot"
    password: "xxxxxxxxxxxxxx"
#Removed for Bluetooth Proxy feature
#captive_portal:
#bluetooth_proxy:
#  active: true
#esp32_ble_tracker:
status_led:
  pin:
    number: GPIO2
    inverted: true
button:
  - platform: restart
  - platform: safe_mode
    name: Restart (Safe Mode)
  - platform: template
    icon: mdi:rocket-launch
    on_press:
      - script.execute: sv_launch
    icon: mdi:rocket
    on_press:
      - script.execute: sv_tli
    icon: mdi:rocket-outline
    on_press:
      - script.execute: lunar_landing
    icon: mdi:alert-octagon
    on_press:
      - dfplayer.stop
      - script.stop: sv_launch
      - script.stop: sv_tli
      - script.stop: lunar_landing
      - script.stop: timer_countdown
      - script.stop: timer_countup
      - script.stop: alarm_1202_1
      - script.stop: alarm_1202_2
      - script.stop: alarm_1201
      - switch.turn_off: saturn_v_exhaust_plume
      - switch.turn_off: lunar_lander_exhaust_plume
      - light.turn_off: saturn_v
      - light.turn_off: lunar_lander
      - light.turn_off: alarm_1201_LED
      - light.turn_off: alarm_1202_LED
      - light.turn_off: fuel_led
      - light.turn_off: saturn_v_section_1_leds
      - light.turn_off: saturn_v_section_2_leds
      - light.turn_off: saturn_v_section_3_leds
      - light.turn_off: saturn_v_section_4_leds
      - light.turn_off: saturn_v_section_5_leds
      - light.turn_off: saturn_v_section_6_leds
      - light.turn_off: lunar_lander_section_1_leds
      - light.turn_off: lunar_lander_section_2_leds
      - light.turn_off: lunar_lander_section_3_leds
      - light.turn_off: lunar_lander_section_4_leds
      - light.turn_off: lunar_lander_section_5_leds
      - light.turn_off: lunar_lander_section_6_leds
text_sensor:
  - platform: wifi_info
    ip_address:
sensor:
  - platform: wifi_signal
    update_interval: 60s
    disabled_by_default: true
  - platform: uptime
# Stuff for the clock display
globals:
  # Affects how the countdown/countup timers are displayed
  - id: clock_display
    type: int
    restore_value: no
    initial_value: '1'
  - id: minute_1
    type: int
    restore_value: no
    initial_value: '0'
  - id: minute_2
    type: int
    restore_value: no
    initial_value: '1'
  - id: second_1
    type: int
    restore_value: no
    initial_value: '2'
  - id: second_2
    type: int
    restore_value: no
    initial_value: '3'
time:
  - platform: sntp
display:
    platform: tm1637
    clk_pin: GPIO16
    dio_pin: GPIO17
    length: 4
    update_interval: 100ms
    lambda: |-
      static int i = 0;
      if (id(sv_launch).is_running() or id(sv_tli).is_running() or id(lunar_landing).is_running()) {
        if (id(clock_display) == 0) {
          // Blank Display
          it.print("    ");
        } else if (id(clock_display) == 1) {
            // Display single minute & seconds with '-'
            it.print(0, "-");
            it.printf(1, "%i.", id(minute_2));
            it.printf(2, "%i", id(second_1));
            it.printf(3, "%i", id(second_2));
        } else if (id(clock_display) == 2) {
          // Display full minutes & seconds, but exclude first minute
            it.print(0, " ");;
        } else if (id(clock_display) == 3) {
            it.printf(0, "%i", id(minute_1));
        } else {}
      else {
        i++;
        if (i > 10)
          it.strftime("%H%M", id(sntp_time).now());
        else
          it.strftime("%H.%M", id(sntp_time).now());
        if (i == 20)
          i = 0;
      if (id(lunar_landing).is_running() and (id(minute_1) == 0) and (id(minute_2) == 1) and (id(second_1) == 0) and ((id(second_2) == 0))) {
        id(fuel_led).turn_on().set_rgb(0.96, 1.0, 0.01).perform();
      } else if (id(lunar_landing).is_running() and (id(minute_1) == 0) and (id(minute_2) == 0) and (id(second_1) == 3) and ((id(second_2) == 0))) {
          id(fuel_led).turn_on().set_rgb(1.0, 0, 0.06).perform();
      } else {}
light:
  - platform: neopixelbus
    type: GRB            #GRBW
    variant: WS2812      #WS2812 #SK6812
    pin: GPIO04
    method:
      type: esp32_rmt
      channel: 0
#  - platform: esp32_rmt_led_strip
#    rgb_order: GRB
#    pin: GPIO04
#    rmt_channel: 0
#    chipset: WS2812
    num_leds: 60
    restore_mode: ALWAYS_OFF
    icon: mdi:rocket
#    internal: true
    on_turn_on:
      - if:
          condition:
            - switch.is_on: saturn_v_exhaust_plume
          then:
      # Turn Off Entire Strip/Partitions
      # Turn the main strip back on
            - light.turn_on: saturn_v
  - platform: partition
    name: "Saturn V - Section 1 LEDs"
    icon: mdi:led-strip
#    internal: true
    segments:
      - id: saturn_v
        to: 59
    effects:
      - addressable_flicker:
          update_interval: 16ms
          intensity: 10%
    name: "Saturn V - Section 2 LEDs"
    icon: mdi:led-strip
#    internal: true
    segments:
      - id: saturn_v
        to: 49
    effects:
          intensity: 10%
    name: "Saturn V - Section 3 LEDs"
    icon: mdi:led-strip
#    internal: true
    segments:
      - id: saturn_v
        to: 39
    effects:
          intensity: 10%
    name: "Saturn V - Section 4 LEDs"
    icon: mdi:led-strip
#    internal: true
    segments:
      - id: saturn_v
        to: 29
    effects:
      - flicker:
          alpha: 95%
          intensity: 5%
    name: "Saturn V - Section 5 LEDs"
    icon: mdi:led-strip
#    internal: true
    segments:
      - id: saturn_v
        to: 19
    effects:
      - flicker:
          alpha: 95%
          intensity: 5%
    name: "Saturn V - Section 6 LEDs"
    icon: mdi:led-strip
#    internal: true
    segments:
      - id: saturn_v
        to: 9
    effects:
      - flicker:
          alpha: 95%
          intensity: 5%
    type: GRBW           #GRB    #GRBW
    variant: SK6812      #WS2812 #SK6812
    pin: GPIO25
    method:
      type: esp32_rmt
      channel: 1
#    rgb_order: GRB
#    pin: GPIO25
#    rmt_channel: 1
#    chipset: WS2812
    num_leds: 6
    icon: mdi:rocket
#    internal: true
    name: "Lunar Lander - Section 1 LEDs"
    icon: mdi:led-strip
#    internal: true
    segments:
      - id: lunar_lander
        to: 0
    effects:
      - flicker:
          alpha: 95%
          intensity: 5%
    name: "Lunar Lander - Section 2 LEDs"
    icon: mdi:led-strip
#    internal: true
    segments:
      - id: lunar_lander
        to: 1
    effects:
      - flicker:
          alpha: 95%
          intensity: 5%
    name: "Lunar Lander - Section 3 LEDs"
    icon: mdi:led-strip
#    internal: true
    segments:
      - id: lunar_lander
        to: 2
    effects:
      - flicker:
          alpha: 95%
          intensity: 5%
    name: "Lunar Lander - Section 4 LEDs"
    icon: mdi:led-strip
#    internal: true
    segments:
      - id: lunar_lander
        to: 3
    effects:
      - flicker:
          alpha: 95%
          intensity: 5%
    name: "Lunar Lander - Section 5 LEDs"
    icon: mdi:led-strip
#    internal: true
    segments:
      - id: lunar_lander
        to: 4
    effects:
      - flicker:
          alpha: 95%
          intensity: 5%
    name: "Lunar Lander - Section 6 LEDs"
    icon: mdi:led-strip
#    internal: true
    segments:
      - id: lunar_lander
        to: 5
    effects:
      - flicker:
          alpha: 95%
          intensity: 5%
  - platform: binary
    name: "Alarm 1201 LED"
    output: output_1201_led
    icon: mdi:alarm-light
  - platform: binary
    name: "Alarm 1202 LED"
    output: output_1202_led
    type: RGB                  #RGB
    variant: WS2812             #SK6812
    pin: GPIO23
    method:
      type: esp32_rmt
      channel: 2
#    rgb_order: RGB
#    pin: GPIO23
#    rmt_channel: 2
#    chipset: WS2812
    num_leds: 1
    icon: mdi:fuel
#    internal: true
    default_transition_length: 0s
switch:
# Saturn V Partition Effects Switch
    name: Saturn V Exhaust Plume
    optimistic: true
    turn_on_action:
      - if:
          condition:
            or:
              - script.is_running: sv_launch
              - script.is_running: sv_tli
          then:
            # Do nothing
          else:
            - if:
                condition:
                  - light.is_on: saturn_v
                then:
            # Individual Partitions/sections
            - light.turn_on:
                brightness: 100%
                red: 100%
                green: 72%
                blue: 0%
                transition_length: 1.5s
            - light.turn_on:
                brightness: 100%
                red: 100%
                green: 60%
                blue: 0%
            - light.turn_on:
                brightness: 100%
                red: 100%
                green: 48%
                blue: 0%
            - light.turn_on:
                brightness: 100%
                red: 100%
                green: 36%
                blue: 0%
            - light.turn_on:
                brightness: 100%
                red: 100%
                green: 12%
                blue: 0%
            - light.turn_on:
                brightness: 100%
                red: 100%
                green: 0%
                blue: 0%
            - delay: 1.5s
            - light.turn_on:
                effect: Flicker
            - light.turn_on:
                effect: Flicker
            - light.turn_on:
                effect: Flicker
            - light.turn_on:
                effect: Flicker
            - light.turn_on:
                effect: Flicker
            - light.turn_on:
                effect: Flicker
    turn_off_action:
# Lunar Lander Partition Effects Switch
    name: Lunar Lander Exhaust Plume
    icon: mdi:rocket
    optimistic: true
    turn_on_action:
      - if:
          condition:
            - script.is_running: lunar_landing
          then:
            # Do nothing
          else:
            - if:
                condition:
                  - light.is_on: lunar_lander
                then:
            - light.turn_on:
                brightness: 100%
                red: 100%
                green: 72%
                blue: 0%
                white: 0%
            - light.turn_on:
                brightness: 100%
                red: 100%
                green: 60%
                blue: 0%
                white: 0%
            - light.turn_on:
                brightness: 100%
                red: 100%
                green: 48%
                blue: 0%
                white: 0%
            - light.turn_on:
                brightness: 100%
                red: 100%
                green: 36%
                blue: 0%
                white: 0%
            - light.turn_on:
                brightness: 100%
                red: 100%
                green: 12%
                blue: 0%
                white: 0%
            - light.turn_on:
                brightness: 100%
                red: 100%
                green: 0%
                blue: 0%
                white: 0%
            - delay: 1.5s
            - light.turn_on:
                effect: Flicker
            - light.turn_on:
                effect: Flicker
            - light.turn_on:
                effect: Flicker
            - light.turn_on:
                effect: Flicker
            - light.turn_on:
                effect: Flicker
            - light.turn_on:
                effect: Flicker
    turn_off_action:
output:
  - platform: gpio
    pin: GPIO21
  - platform: gpio
    pin: GPIO22
uart:
  tx_pin: GPIO19
  rx_pin: GPIO18
  baud_rate: 9600
dfplayer:
script:
  - id: sv_launch
    mode: single
    then:
      - dfplayer.play_folder:
          folder: 1
          file: 1
      # Start countdown timer
      - globals.set:
          value: '1'
      - globals.set:
          value: '0'
      - globals.set:
          value: '0'
      - globals.set:
          value: '3'
      - globals.set:
          value: '1'
      - script.execute: timer_countdown
      - delay: 22.5s
      - switch.turn_on: saturn_v_exhaust_plume
      - light.turn_on:
          brightness: 25%
          red: 100%
          green: 72%
          blue: 0%
      - light.turn_on:
          brightness: 25%
          red: 100%
          green: 60%
          blue: 0%
      - light.turn_on:
          brightness: 25%
          red: 100%
          green: 48%
          blue: 0%
      - light.turn_on:
          brightness: 25%
          red: 100%
          green: 36%
          blue: 0%
      - light.turn_on:
          brightness: 25%
          red: 100%
          green: 12%
          blue: 0%
      - light.turn_on:
          brightness: 25%
          red: 100%
          green: 0%
          blue: 0%
      - delay: 1.5s
      - light.turn_on:
          effect: Flicker
      - light.turn_on:
          effect: Flicker
      - light.turn_on:
          effect: Flicker
      - light.turn_on:
          effect: Flicker
      - light.turn_on:
          effect: Flicker
      - light.turn_on:
          effect: Flicker
      - delay: 7.5s
      - light.turn_on:
          brightness: 100%
      - light.turn_on:
          brightness: 100%
      - light.turn_on:
          brightness: 100%
      - light.turn_on:
          brightness: 100%
      - light.turn_on:
          brightness: 100%
      - light.turn_on:
          brightness: 100%
      # Keep script running until audio is done
      - delay: 30s
      # Keep script running so clock doesn't display until the countup would stop making sense
      - delay: 100minutes
  - id: sv_tli
    mode: single
    then:
          folder: 1
          file: 2
      - globals.set:
          value: '3'
      - globals.set:
          value: '4'
      - globals.set:
          value: '9'
      - globals.set:
          value: '4'
      - globals.set:
          value: '5'
      - script.execute: timer_countup
# Added full SV startup here because using the normal startup with transition length messed things up (only added in case it's not already on)
      - light.turn_on:
          brightness: 100%
          red: 100%
          green: 72%
          blue: 0%
      - light.turn_on:
          brightness: 100%
          red: 100%
          green: 60%
          blue: 0%
      - light.turn_on:
          brightness: 100%
          red: 100%
          green: 48%
          blue: 0%
      - light.turn_on:
          brightness: 100%
          red: 100%
          green: 36%
          blue: 0%
      - light.turn_on:
          brightness: 100%
          red: 100%
          green: 12%
          blue: 0%
      - light.turn_on:
          brightness: 100%
          red: 100%
          green: 0%
          blue: 0%
      - light.turn_on:
          effect: Flicker
      - light.turn_on:
          effect: Flicker
      - light.turn_on:
          effect: Flicker
      - light.turn_on:
          effect: Flicker
      - light.turn_on:
          effect: Flicker
      - light.turn_on:
          effect: Flicker
      - delay: 20.7s
      - delay: 35s
      - delay: 50minutes
  - id: lunar_landing
    mode: single
    then:
      # Clear clock
      - globals.set:
          value: '0'
          folder: 1
          file: 3
      - delay: 33s
      - switch.turn_on: lunar_lander_exhaust_plume
      - light.turn_on:
          brightness: 100%
          red: 100%
          green: 72%
          blue: 0%
          white: 0%
      - light.turn_on:
          brightness: 100%
          red: 100%
          green: 60%
          blue: 0%
          white: 0%
      - light.turn_on:
          brightness: 100%
          red: 100%
          green: 48%
          blue: 0%
          white: 0%
      - light.turn_on:
          brightness: 100%
          red: 100%
          green: 36%
          blue: 0%
          white: 0%
      - light.turn_on:
          brightness: 100%
          red: 100%
          green: 12%
          blue: 0%
          white: 0%
      - light.turn_on:
          brightness: 100%
          red: 100%
          green: 0%
          blue: 0%
          white: 0%
      - delay: 1.5s
      - light.turn_on:
          brightness: 100%
          red: 81%
          green: 96%
          blue: 100%
      - globals.set:
          value: '2'
      - globals.set:
          value: '0'
      - globals.set:
          value: '4'
      - globals.set:
          value: '0'
      - globals.set:
          value: '0'
      - light.turn_on:
          effect: Flicker
      - light.turn_on:
          effect: Flicker
      - light.turn_on:
          effect: Flicker
      - light.turn_on:
          effect: Flicker
      - light.turn_on:
          effect: Flicker
      - light.turn_on:
          effect: Flicker
      - delay: 90.75s
      # First 1202 alarm
      - script.execute: alarm_1202_1
      - delay: 30.75s
      # Second 1202 alarm
      - script.execute: alarm_1202_2
      - delay: 13s
      # Throttle Down
      - light.turn_on:
          brightness: 50%
      - light.turn_on:
          brightness: 50%
      - light.turn_on:
          brightness: 50%
      - light.turn_on:
          brightness: 50%
      - light.turn_on:
          brightness: 50%
      - light.turn_on:
          brightness: 50%
      - delay: 17.3s
      # 1201 alarm
      - script.execute: alarm_1201
      - delay: 28.7s
      - delay: 30s
      - delay: 14.5s
      # Engine shutdown
      - light.turn_off:
      - light.turn_off:
      - light.turn_off:
      - light.turn_off:
      - light.turn_off:
      - light.turn_off:
      # Stop countdown
      - delay: 50.5s
  - id: alarm_1202_1
    mode: single
    then:
      - repeat:
          count: 16
          then:
            - light.turn_on:
                effect: None
            - delay: 412ms
            - delay: 412ms
  - id: alarm_1202_2
    mode: single
    then:
      - repeat:
          count: 19
          then:
            - light.turn_on:
                effect: None
            - delay: 412ms
            - delay: 412ms
  - id: alarm_1201
    mode: single
    then:
      - repeat:
          count: 17
          then:
            - light.turn_on:
                effect: None
            - delay: 400ms # Changed from 412ms to try and get it to sync better. Needed to be faster
  - id: timer_countdown
    mode: restart
    then:
      - delay: 1s
      - if:
          condition:
            and:
              - lambda: 'return id(second_2) == 0;'
              - lambda: 'return id(second_1) == 0;'
          then:
            - lambda: |-
                id(minute_2) -= 1;
                id(second_1) = 5;
                id(second_2) = 9;
          else:
            - if:
                condition:
                then:
                  - lambda: |-
                      id(second_1) -= 1;
                      id(second_2) = 9;
                else:
                  - lambda: |-
                      id(second_2) -= 1;
      - if:
          condition:
            and:
              - lambda: 'return id(minute_2) == 0;'
          then:
            - lambda: |-
                id(clock_display) = 2;
          else:
  - id: timer_countup
    mode: restart
    then:
      - delay: 1s
      - if:
          condition:
            and:
              - lambda: 'return id(clock_display) == 2;'
              - lambda: 'return id(minute_1) != 0;'
          then:
            - lambda: |-
                id(clock_display) = 3;
      - if:
          condition:
            and:
              - lambda: 'return id(minute_2) == 9;'
              - lambda: 'return id(second_1) == 5;'
              - lambda: 'return id(second_2) == 9;'
          then:
            - lambda: |-
                id(minute_1) += 1;
                id(minute_2) = 0;
                id(second_1) = 0;
                id(second_2) = 0;
          else:
            - if:
                condition:
                  and:
                then:
                  - lambda: |-
                      id(minute_2) += 1;
                      id(second_1) = 0;
                      id(second_2) = 0;
                else:
                  - if:
                      condition:
                      then:
                        - lambda: |-
                            id(second_1) += 1;
                            id(second_2) = 0;
                      else:
                        - lambda: |-
                            id(second_2) += 1;
