Ethernet communication with ultratronics board!
Now I can command 'Thor robot' from TCP client
A project log for 'Thor' robot with addons and GUI
Thor robot based on the author AngelLM
It runs softer than last time.
Everything has been optimized, I'm working on the gamepad integration. After that I'm going to make a little pcb in the middle of the base to bring all connections to there. From that position I can plug in every wire that Is needed to complete the robot.
I'm not happy with all the wires hanging there.
You are unstoppable! :-)
