'STANDING CONTROLLER BOX FOR THOR ROBOT ARM'
A project log for 'Thor' robot with addons and GUI
Thor robot based on the author AngelLM
dannyvandenheuveldannyvandenheuvel • 02/04/2017 at 19:00•11 Comments
For all those wanted a seperate controller box, there's room enough for the ultratronics pro V1.0 board, if you want a empty holes box, just ask!
If you want some dimensions, no problem :-)
Hope you like it! (for some personal modifications just sent me a comment!)
Olaf Baeyens wrote 02/12/2017 at 03:24 • point
Hello Danny, now that I have the box in my hand. I am wondering if the box should not be upside down so that the ventilator is on the top?
I assume that you want to blow hot air out, and that will rise. The ventilator could of course blow cold air in but that way you also suck in dust that tends to be at the ground.
Nothing prevents me to put the box upside down, just your cool blue stripes would be hidden.
dannyvandenheuvel wrote 02/12/2017 at 10:08 • point
Cold air in, Hot air out :-)
That was my intention, you can turn it upside down. It was a hard job for your printer, you work with one extruder? That will be the problem, other printers use a second material for the structures that can be resolved. It has a better connection with the heating bed. Then you have printers with a closed enviroment  (heating room). It's because I use it for bussiness tasks I could buy a professional machine, you can not compare it with the home versions. There's a real difference in quality and strength.
Olaf Baeyens wrote 02/12/2017 at 12:10 • point
There is an upgrade for multiple materials but this one I only have one extruder.
I did not start this Thor project because it was easy, but because it was hard :-) That is where you learn the most.
Olaf Baeyens wrote 02/08/2017 at 21:36 • point
I just simulated the case will be 13H print, the case cover will be around 8 hour print. I may print it this weekend.
Olaf Baeyens wrote 02/06/2017 at 21:31 • point
Hello Danny, I already printed most parts but the big box is about 13H job. So that one is postphoned untill I can find 13H were I can be near my printer. That is no sooner than next week.
dannyvandenheuvel wrote 02/07/2017 at 08:32 • point
I am looking forward to see the result : - )
ReapeRum wrote 02/04/2017 at 23:41 • point
this looks awesome well i bet you know what your doing could you look at my project and ,maybe get advice?
Olaf Baeyens wrote 02/04/2017 at 20:57 • point
It is christmas! Thanks for that beautful present.
dannyvandenheuvel wrote 02/04/2017 at 21:41 • point
Files online :-)
Olaf Baeyens wrote 02/04/2017 at 22:22 • point
Already printing the 2 sides (4 hour print) wondering if it will fit on my 3D printer
dannyvandenheuvel wrote 02/04/2017 at 21:47 • point
btw, You will find the button (with white led) and fan at www.gotron.be
