The set up is currently collecting data from within a bin filled with canola. It is operating as expected, and I will continue to monitor the temperature variations so that I can best decide when a text alert should be sent out.
For the most part the project is done and working!
Later, could be awhile, I will give a more descriptive update and more in depth instructions of how to build.
