Hi Hackaday,
Today i introduces you some ability what esplay micro can do. I port micropython with lvgl module built-in from littlevgl repository here. Picture will explain everything.
the code for screenshot above
import lvgl as lv
lv.init()
import lvesp32
import ILI9341 as ili
d = ili.display()
d.init()
disp_buf1 = lv.disp_buf_t()
buf1_1 = bytes(320*10)
lv.disp_buf_init(disp_buf1,buf1_1, None, len(buf1_1)//4)
disp_drv = lv.disp_drv_t()
lv.disp_drv_init(disp_drv)
disp_drv.buffer = disp_buf1
disp_drv.flush_cb = d.flush
disp_drv.hor_res = 320
disp_drv.ver_res = 240
lv.disp_drv_register(disp_drv)
# Animation helper class
class Anim(lv.anim_t):
def __init__(self, obj, val, size, exec_cb, path_cb, time=500, playback = False, ready_cb=None):
super().__init__()
lv.anim_init(self)
lv.anim_set_time(self, time, 0)
lv.anim_set_values(self, val, val+size)
if callable(exec_cb):
lv.anim_set_custom_exec_cb(self, exec_cb)
else:
lv.anim_set_exec_cb(self, obj, exec_cb)
lv.anim_set_path_cb(self, path_cb )
if playback: lv.anim_set_playback(self, 0)
if ready_cb: lv.anim_set_ready_cb(self, ready_cb)
lv.anim_create(self)
# An animated chart
class AnimatedChart(lv.chart):
def __init__(self, parent, val, size):
super().__init__(parent)
self.val = val
self.size = size
self.max = 2000
self.min = 500
self.factor = 100
self.anim_phase1()
def anim_phase1(self):
Anim(
self,
self.val,
self.size,
lambda a, val: self.set_range(0, val),
lv.anim_path_ease_in,
ready_cb=lambda a:self.anim_phase2(),
time=(self.max * self.factor) // 100)
def anim_phase2(self):
Anim(
self,
self.val+self.size,
-self.size,
lv.anim_path_ease_out,
ready_cb=lambda a:self.anim_phase1(),
time=(self.min * self.factor) // 100)
# Create the chart
scr = lv.obj()
chart = AnimatedChart(scr, 100, 1000)
chart.set_width(scr.get_width() - 100)
chart.align(scr, lv.ALIGN.CENTER, 0, 0)
series1 = chart.add_series(lv.color_hex(0xFF0000))
chart.set_type(chart.TYPE.POINT | chart.TYPE.LINE)
chart.set_series_width(3)
chart.set_range(0,100)
chart.init_points(series1, 10)
chart.set_points(series1, [76,40,40,40,50,40,50,90,95,90])
chart.set_x_tick_texts('a\nb\nc\nd\ne', 2, lv.chart.AXIS.DRAW_LAST_TICK)
chart.set_x_tick_length(10, 5)
chart.set_y_tick_texts('1\n2\n3\n4\n5', 2, lv.chart.AXIS.DRAW_LAST_TICK)
chart.set_y_tick_length(10, 5)
chart.set_div_line_count(3, 3)
chart.set_margin(30)
# Create a slider that controls the chart animation speed
def on_slider_changed(self, obj=None, event=-1):
chart.factor = slider.get_value()
slider = lv.slider(scr)
slider.align(chart, lv.ALIGN.OUT_RIGHT_TOP, 10, 0)
slider.set_width(30)
slider.set_height(chart.get_height())
slider.set_range(10, 200)
slider.set_value(chart.factor, 0)
slider.set_event_cb(on_slider_changed)
# Load the screen
lv.scr_load(scr)
