I hooked up some power resistors (1-8R 10W) to the various outputs and ran it through its paces.
First up was supplying 8V @ 1A to an 8R resistor hooked up to the motor controller (8V / 8R should be roughly 1A).
Next, I attached a 4.5R load to the 3.3V output (2x1R in parallel with a 4R in series). The LM111733V is limited to 800mA sources, so that should give 733mA that's around 2.5W. After about 30s, it starts to short circuit; I suspect this is due either to the traces not being able to supply the current or the resistors overheating and causing problems; at 10W, I wouldn't suspect that but they did feel pretty warm afterwards.
Finally, I tried supplying 8V @ 1.1A with 4.5R load on the 5V outputs (which should be about 1.1A). There's a 0.2V drop across the load, which I suspect is due to the load.
I did try switching the motor kill switch while the load was applied and it didn't fuse, which is a good sign.
The tests indicate that I should aim for improved thermal dissipation and widen up my traces.
