V1
A project log for REV Expansion Hub Type-C Adapter
Adding a more robust connector & USB Hub to the REV Expansion Hub
thomas-bladykasThomas Bladykas • 07/23/2019 at 14:38•0 Comments
This is a little journey back into the prototyping for this project.
It all started with a dream...
The original idea:
  1. Create a board that would simply convert the Mini-B connector on the REV Expansion Hub to a Type-C port.
  2. Include ESD protection on the USB lines for extra disconnect resistance.
  3. Make sure it's sturdy and can last for much longer than a Mini-B cable.
And thus, the mini V1 prototype was born:
However, after I did some polling of interested customers, about 2/3 of teams responded that they would also like to use a webcam on their robot. That would mean introducing a USB hub into the wiring of the robot, which can lead to disconnects from the sheer number of connections.
So what's the solution? Slapping a USB hub controller on the board, obviously.
The IC used was a USB2422 from SMSC (Microchip). This is the absolute smallest 2-port USB hub chip available. The LDO was an NCP170 LDO. Unfortunately, I learned the hard way that you can't just willy-nilly route the USB lines on a 2-layer board, because no matter what I tried, I was always greeted with USB errors.
It was time for some research...
