Preliminary version of UI for the test setup done.
It takes more time then I expected (around 14 hours).
It looks ugly, but I think functional enough.
Measurement tab:
- Load gauge for each truck wheel
- Total truck load
- Overload/underload data and signalization for each axle.
- Max load field for each axle (kg)
- Load difference field for each axle (%)
- Load difference error indicator for each wheel
- Numberplate/ Vehicle type - for use with numberplate recognition system and vehicles database.
Unloaded:
Loaded:
With load errors(first axle load difference error, difference more than 10%):
Calibration tab
For each Load cell - Modbus interface:
- CALIBRATION CODE field (cal. code is different for each Load cell - Modbus interface to protect from unexpected calibration)
- CALIBRATION WEIGHT field (you need to type calibration load weight in this field)
- Button to calibrate on zero load
- Button to calibrate on test load
- Button to set zero
- Gauge
- Sensor error indicator.
- Zero point indicator
In editor it looks like this:
Mathematics is the good subject in which you can learn about the measurement and calculate the distance by using the formula and now I use https://edubirdie.net/howitworks to manage my college work. Students should give more attention to learn about this subject properly. It is the real subject which is interesting.
