As this is an ongoing project there is still some things I want to add/improve:
- Replace the Y axis shafts for shorter ones.
- Place an easy to install/remove base to hold the work paper.
- Redesign the penholder to make it stiffer.
- Add a fan to decrease the motor drivers’ temperatures.
- Replace the wooden movable pieces for acrylic ones (or at least paint them).
- Tidy up the wiring.
Daniel
