Distortion in music is everywhere—unavoidable perhaps. The majority of distortion circuits usually amplify a signal, then feed it into a diode clipping stage and call it a day. But, there are non-linearities within diodes that can be exploited. This circuit does something different—rather than amplifying, then passing through the diode clipper stage, this circuit passes a signal through a diode clipper, then through a two-stages of transistor amplifiers.
The first amplifier stage will amplify a signal enough to overdrive the second transistor amp stage. When this happens—to use the most technical terms—it will sound pretty friggin' sweet.
TODO:
- Design the amplifier stages
Components
2×
1N4007
Discrete Semiconductors / Diodes and Rectifiers
The circuit is going pretty well so far. The problem I'm having is with the transistor amplifiers.
When I first attempted the first stage of the amplifier, I ended up producing a rather nice and smoky aroma—like there was a component barbeque somewhere. I ended up frying one of the coupling capacitors, so that was great.
I've decided to go with a common-emitter amp because, well, who doesn't use those?
Anywho, I need to get back to finishing the design for the first stage. I'm planning on having variable gain for it and the second stage, but I think I will incorporate potentiometers into them later.
