The red part is X711 module for straing gauge.
The motor driver that I'm using is way overpowered for this motor. The window motor will draw ardoun 1.5A at no load and 4A at stall torque. I'm saying this because this motordriver is pretty expensive and you could get away with weaker and cheaper one.
Kristjan Berce
