I fitted one PCB set to my last dirtyPCBs order, and received them:
![](https://cdn.hackaday.io/images/2051461623879943807.jpg)
As you see I made two separate PCBs to spare board space.
The RJ50 and main boards will be connected with a blank PCB strip:
![](https://cdn.hackaday.io/images/4891301623879913994.jpg)
![](https://cdn.hackaday.io/images/2452541623879929508.jpg)
A project log for Symbol LS4208 barcode reader retrofit
I have had a broken Symbol LS4208 barcode reader laying around for a while. I decided to give it a new life.
