Vďaka tomu že APM4953 je "dual P-channel" stačia na 1 H-mostík len 4 tranzistory a pri cene cca 0.05$/kus sa jedna o lacný h-mostík.
Krátky test:
H mostik s 4x APM4953 (Dual P-channel mosfet 30V 4.9A) +optoclen || tranzistor + Pic12Fxxx
Krátky test:
Hmostik_gerb.zipGerber filesZip Archive - 148.72 kB - 09/04/2019 at 18:33 |
pic12f683.pdfThe Low Pin-count (8) PIC® Flash microcontroller products offer all of the advantages of the well recognized mid-range x14 architecture with standardized features including a wide operating voltage of 2.0-5.5 volts, on-board EEPROM Data Memory, and nanoWatt Technology. Standard analog peripherals include up to 4 channels of 10-bit A/D, an analog comparator module with a single comparator, programmable on-chip voltage reference and a Standard Capture/Compare/PWM (CCP) module.Adobe Portable Document Format - 2.38 MB - 08/31/2019 at 15:56 |
APM4953v2.pdfDual P-Channel Enhancement Mode Mosfet datasheetAdobe Portable Document Format - 494.68 kB - 08/31/2019 at 15:55 |
