The ELB REV4 Provides a powerful and flexible selection across the full spectrum of applications. For example, specs like the -40 to 85 c temperature range peripherals make it ideal for industrial applications like telecom, automotive, control systems, Medical, processing with Ethernet, USB, Touch controller. LTE modem, certified Wi-Fi 802.11 a/b/g/n with optional MIMO. The ELB-REV4 is also highly integrated with support for a Linux operating system.
It supporting the 1Ghz Sitara AM335X ARM Cortex A8 processor from Texas Instruments with a rich 2D/3D graphics accelerator.
Hardware Specifications:
- Texas Instruments Sitara AM335X
High performance with 1GHzCortex-A8
sPowerVR SGX530 graphics core
- 512 MB DDR3
- 4GB eMMC Memory
- SD card slot
Display Support
- Resolution 1400 x 1050 x 24 bpp
- LCD: Parallel RGB
- 4/5-wire resistive touch panel
- 10/100Mbps Ethernet
- Gigabit Ethernet MAC{RGMII)
- Certified 802.11 a/b/g/n with MIMO
- LTE modem for various regions
Networking
CAN, SPI, I2C, GPIO (25). Time/Counter (2), Switches/Buttons (4) Power Pin, reset pin, Wakeup pin, LED indicator (8), -40 -85 C industrial temperature
USB
- USB 2.O OTG
- USB 2.O Host (2)
- Serial Interfaces
- RS232 (2)
- RS485 (2)
Other Interfaces:
Support:
OS Support
- Linux
Power:
- Single 5V 2.5 A adapter
- Digital I/O 33 V
- AIN pin 1.8 V
ssla-couk
ESP32andmore
joshua.vader
