- . Full resource of UNO R3
- . Onboard Virtual USB HID device
- .The USB HID can be programming the board as a keyboard / mice / etc… with HID class device
- . Ground test terminal
- . TQFP-48 MD-3248P MCU
- . Analog power and digital power and ground are separated
- . Onboard 4.096V/2.048V voltage reference source
- . 4.096V for PWM-DAC
- . AREF for MCU ADC selectable between 4.096V and 2.048V
- . 4 channel onboard PWM-DAC
- . CH0/1 with 16bit resolution
- . CH2/3 with 12bit resolution
- . 5 channel High Voltage Analog input
- . Range 32V with 4.096V AREF
- . Range 16V with 2.048V AREF
- . Onboard 3 tack switch buttons and 3 LEDs for fast programming
○ Massduino MD-3248P with 32KB Flash , 2KB SRAM
○ Fully Arduino IDE development
○ Full arduino UNO resource support
○ Rich additional resource
3 user programmable LEDs
4 CH pwm DAC (2 ch fast mode and 2 ch high resolution mode)
5 CH HV ADC (Max input 32V)
Onboard 4.096V and 2.048V voltage reference source
○ Virtual USB , make the board as a HID device (Keyboard / Mice etc.)
Recommend purchase link:https://www.ebay.com/itm/223115047614
