I have found a bug that happened when DEBUG directive was active.
I forgot to save the _temp_register_ on the beginning of the ISR and it caused the AVR to crash and reset while printing debug data to serial console.
ISR (INT0_vect, ISR_NAKED) { asm volatile ( "push __tmp_reg__\n\t" // <- THAT WAS MISSING! "in __tmp_reg__,__SREG__ \n\t" // Save Status register "push r17\n\t" // keep PINB state "push r18\n\t" // keep PIND state "push r19\n\t" // temp Data to write on Output "push r20\n\t" // register to read keymap "push r26\n\t" // Pointer to Keymap "push r27\n\t" // ...
After that was fixed the project began to behave like expected, so I am releasing it as a beta.
I Will change the structure of the ".h" files to make easier to define new keyboard matrices (ZX81,Speccy,Ace) as well as new keyboard layouts (pt_br, en, etc).
