Hey everyone, I finally had some time to work on projects again, and reworked the Op-Amp explorer board. I changed the general layout to make it more intuitive for a beginner, the components are laid out on the board in representative locations from the schematic. There are now also test points, thanks to a suggestion made to me. This should allow for quick measurements from points in the circuit that were not accessible in the previous revision.
