Need to decide
- whether to further simplify
or go the other way and ...
- add further general purpose registers
- and IO - IO might be achieved by memory mapping the devices, or by adding further special purpose registers etc
Also ...
- consider adopting a higher level language - ? something like ttlcpu ?
- deciding whether to use higher level instructions to drive the microcode or just put this complexity in the Assembler (or Compiler) instead
And ..
- working out how to integrate with VGA - probably using a NovaVGA and some shift registers as IO.
- working out how to integrate with input devices (eg a potentiometer if we were to implement a Pong game for instance)
