The musical box lives!
A project log for SPAM-1 - 8 Bit CPU
8 Bit CPU in 7400 with full Verilog simulator and toolchain
john-lonerganJohn Lonergan • 06/26/2020 at 01:33•0 Comments
I have now reorganised the simulation so that I have two competing implementations of the control logic.
There is a large net saving in control logic chips as expected, at the expense of spreading the instruction over 48 bits of rom. Of course CPU's like the MIPS use narrower instructions but my approach means no tricky decode logic; I can live with that.
A side effect of this redesign is
This approach doesn't use all the bits in the ROM's. There are few unused bits in the middle and I'm considering whether these might be used to implement conditional instructions like the early ARM chips. Possibly as an alternative to the more common jump approach I'm using already. So room for experimentaiton too.
So I think it's worth it and I'll stash the old more complex control logic approach.
