Have adopted an ARM-like approach by making all instructions conditional rather than just jumps and also used a spare bit to control whether a given op sets the status flags.
This makes the whole desigh more symetrical and appealing to me.
This was pretty easy to add once I realised that all I have to do was to hook up one of the unused enable pins on my "target" decoders .Enable2_bar(_do_exec)
hct74138 targ_dev_08_demux(.Enable3(1'b1), .Enable2_bar(_do_exec), .Enable1_bar(targ_dev[3]), .A(targ_dev[2:0])); hct74138 targ_dev_16_demux(.Enable3(targ_dev[3]), .Enable2_bar(_do_exec), .Enable1_bar(1'b0), .A(targ_dev[2:0]));
(https://github.com/Johnlon/spam-1/blob/master/verilog/cpu/controller.v)
This relied on creating some simple decoding logic based on a 74151 multiplexer as shown below. But that work brought me to an understanding of the difference between "inertial" and "transport" delays in Verilog.. I was expecting some glitches due to the chip's published timings but they didn't show up in the simulation because I'd effectively used "inertial delays". I reworked the timings to let through all glitches by implementing "transport delays"; but that's not how real silicon works either because real silicon will not propagate short lived pulses. I'll probably write more on this.
The additional control logic is simulated here..
