Control LIFX bulb with your hand movement
Use your pliers to bend the headers of the ultrasonic sensor, this way the sensor will be facing up when you solder it onto the perfboard.
This is optional, but if you would like to reuse your Particle Photon, trim 2 female headers to match the male headers of Photon.
Trim your perfboard to a 50 x 50 mm square. I find it easier and cleaner to do this with a diagonal cutter instead of a saw.
Mark the hole for the ultrasonic sensor headers before temporarily removing it from the board.
Wire up according to the schematic and reinsert the sensor when finished.
Flip the board and solder all the connections.
Download the STL files, I printed mine with the following settings:
Afterward, line up the ultrasonic sensor with the cutout, and snap fit the case together. The electronics should fit pretty snug inside.
