Woo hoo. I have it working under the RunCPM emulator.
A>EFZ80 eForth v1.00 WORDS COLD 'BOOT hi VER WORDS SEE .ID >NAME ?CSP !CSP .S DUMP dm+ _TYPE VARIABLE CREATE USER IMMEDIATE : call, ] ; OVERT $COMPILE $,n ?UNIQUE ." $" ABORT" WHILE ELSE AFT THEN REPEAT AHEAD IF AGAIN UNTIL NEXT BEGIN FOR RECURSE $," LITERAL COMPILE [COMPILE] , ALLOT ' QUIT CONSOLE I/O HAND FILE xio PRESET EVAL ?STACK .OK [ $INTERPRET abort" ABORT NULL$ THROW CATCH QUERY EXPECT accept kTAP TAP ^H NAME? find SAME? NAME> WORD TOKEN CHAR \ ( .( PARSE parse ? . U. U.R .R ."| $"| do$ CR TYPE SPACES SPACE PACE NUF? EMIT KEY ?KEY NUMBER? DIGIT? DECIMAL HEX str #> SIGN #S # HOLD <# EXTRACT DIGIT PACK$ -TRAILING FILL CMOVE @EXECUTE TIB PAD HERE COUNT 2@ 2! +! PICK DEPTH >CHAR BL ALIGNED CELLS CELL- CELL+ */ */MOD M* * UM* / MOD /MOD M/MOD UM/MOD WITHIN MIN MAX < U< = ABS - DNEGATE NEGATE NOT + 2DUP 2DROP ROT ?DUP FORTH forth LAST NP CP CURRENT CONTEXT HANDLER HLD 'NUMBER 'EVAL CSP #TIB >IN SPAN tmp BASE 'PROMPT 'ECHO 'TAP 'EXPECT 'EMIT '?KEY RP0 SP0 doUSER UP doVAR BYE TX! ?RX !IO UM+ XOR OR AND 0< OVER SWAP DROP DUP SP! SP@ RP! RP@ R> R@ >R C@ C! @ ! branch ?branch next EXECUTE EXIT doLIST doLIT ok 65 EMITA ok BYE RunCPM Version 3.7 (CP/M 2.2 60K) A>
It also can be conditionally assembled for the 8080 by changing one equate.
Will check code into GitHub in a moment.
Now to look for some eForth tests.
Congrats!
Thanks, I'll give this project a rest now while I sort out hardware issues with my Z80 and 8080 platforms. And deal with other projects on my plate. Long delivery times from suppliers make one multitask. 😁
