So I made a nice mistake on rev-00 of the PCB. I used metric 0603 and not (imperial?) 0603. Also the pads for the attiny SOIC were incorrect(narrow). So that has been fixed also. The new files are uploaded. I should not work at NASA.
On a positive note I test fit the rest of the components on the board and it was a perfect fit. Even the buttons worked with the case from Shapeways. I was very surprised I got that right the first try. The SOIC programming claw from sparkfun grips nicely on the Attiny and I'm looking forward to my Rev-01 boards from oshpark.
Next time it is not 1am I will get around to posting a better case.
