Version 3 #2
A project log for Microcontroller based curve tracer
Electronic Curve tracer for measure and compare components on circuit boards
mt-tthMáté Tóth 03/15/2018 at 17:390 Comments
Hi everyone,
I did some progress on the Version 3 prototype, it has more working function then before. I am still facing with some hardware butg, what I inherit from the Version 2. I found out the original circuit has big issues, because I did not had Oscilloscope when I developed the Vesion 2 I could not see these issues before. The Voltage ranges was messed up. Most of the issues I could fix, but it has still some.
A little bit about the spec:
Ranges123456
Resistance250ohm2k5k10k15k20k
Voltage0,5V1,8V3,3V6V8V10V
Current2mA0,9mA0,66mA0,6mA0,5mA0,5mA
Output1mW1,6mW2,2mW3,6mW4mW5mW
And the video:
