As I mentioned earlier I wanted to change the two AVR MCUs from the original design to a single 32bit one.
Here are my selection criteria:
- Two at least 12bit DAC channel - One channel is used for the sine wave generation, the second maybe used for the pulse generation (not designed, decided yet, but better if it is available)
- Two at least 12bit ADC channel - For measuring current and voltage on the DUT. If parallel sampling and/or differential input available is good but not requirement
- DMA for DAC operation
- 32 bit core - ARM Cortex-Mx prefered
- Arduino framework support, free, native C/C++ IDE support (I haven't decided between the two, so the support is necessary)
- Low cost development board
- Easily solderable (for me. Means: TQFP accepted, QFN, BGA not - I know this is my personal limitation, but I don't want to learn it right now)
Based on the specs above my choice is an STM32F303RET6:
And the development board for it:
I ordered the board from Farnell yesterday. Today arrived:
Next: seting up the development environment
SUF
