Functioning with 2 channel!
A project log for Microcontroller based curve tracer
Electronic Curve tracer for measure and compare components on circuit boards
mt-tthMáté Tóth • 03/13/2017 at 22:12•0 Comments
It was not to difficult and not too much work to made the second channel ussable. Whit this I can compare 2 component, and see if those have any different.
I made a little video about how it is works now.
In the video the first test was between a 6.2V zener and a 8.2V zener diode.
In the second test I used a LED and a normal diode.
