Hi everyone,
I know you are waiting really long time to see how is this project develops. I had a bit of time recently and I could work on the Version 3 electronic development and bulding ass well. It took me a lot of time, to start it, but I am getting ready to finish it in the next 2 week.
Some improvement, I managed to build it a bit smaller then what I thought and it may get smaller with time. Because it is still a prototype, I am building it on a proto board, and after if everything works I will designe a PCB for it.
The improvement was, I managed to get more resolution on the Voltage ranges, but it is not has any big deal in Version 3, because it will be have 6 Voltage range, but if I need in theary it can be handle 255 Voltage range now if it needed. Also if I redo at Version 2 I can use the 255 voltage ranges. :D
Also I would like to improve the frequancy ranges, which has at the moment 6 ranges.
As I mentioned before the Version 3 specification will be:
- 6 Frequancy range between 50Hz and 20KHz
- 6 Resistance range between 47ohm and 25kohm
- 6 Voltage range between 0,2V and 28V peak to peak
Some picture :
The improved circuit designe:
