After a considerable amount of debugging, (with the help of @agp.cooper and @Alastair Hewitt ) I was able to get solid 40x30 text output from my 8-bit video board! I'm using a 8x16 font with the resolution of 640x480@60Hz and driving it with a pixel clock of 12.5875MHz, which is within the range of the clock speeds supported for the MC6845. I've got a ton of stuff to test before making a new revision of the board, but..... it works!
Dave's Dev Lab
“cga snow” effect will be observed when writing to video memory from the system bus. The circuit needs write buffering or a wait signal while crtc accessing video memory.
yeah i am doing static writes to the memory at this stage so i am not experiencing any "snow" effects, but yes, i intend to work on the wait signal similar to what was implement in the PCjr system....
