Includes:
- Mesh usb adapter codes (for esp32/esp2866).
- Mesh gateway codes (Convert messages between mesh network and MQTT broker)
- Slave node example codes (Slave node can read sensors, control switches/lights or something else)
Features:
- Works on EspNow broadcast
- Nearly instant connection after poweron
- Maximum number of slave nodes: unlimited
- Flooding mesh support
- a message cache. If a received packet is already found in the cache --> it will not be retransmitted or handled again
- Mesh nodes use MQTT service (subscribe/publish)
- Master node (USBAdapter=ESP32 or ESP2866) is connected to RaspberryPi's USB port
- Each Nodes can communicate with each other
- ESP32, ESP2866, ESP01
- Ping about 40-60ms
- ttl support
- Battery node support
- AES128
- Retransmission support
- Request/Reply support
- Send and pray support (Send a message to all nodes without reply/ack)
- Easy to configure (just set channel, secure keys and bsid)
- Simple mqqt interface. All nodes can use mqtt services via master node (subsribe,unsubscribe,publish,get).
- MQTT local cache on raspberry
- Arduino
____________________________________ ( ) | | ( Internet ) | | (____________________________________) ^ |MQTT | +--------------------|-------+ | RaspberryPi V | |-------------+ +--+-------| | MeshGateway |<->| MQTT | +-------------------------------------+ | | | broker | | ESPNOW mesh network | +-----+-------+---+----------+ | Node6 | ^ | Node1 Node3 | | USB(SerialData) | +------------+ Node3 Node5 | +------------------------------>| USBAdapter | Node4 | | | (Master) | NodeX Node7 | | +------------+ | +-------------------------------------+
Flooding mesh network
In this network example ttl must be >= 5
SlaveNode | | Message from master to BatteryNode | ---------------------------+ | ttl=5 ttl=4 | SlaveNode-------MasterNode-------------SlaveNode | | | | | | | | | | | | | SlaveNode | | | | | | | | | | +------------------------------------------------> | | ttl=3 ttl=2 ttl=1 SlaveNode-------SlaveNode-------------SlaveNode-------SlaveNode-------------SlaveNode---------BatteryNode | | | | | | | | | | | | +-----------SlaveNode-----------------+
Message relay
The Master sends a request to the farthest node and the farthest node replies.
Arduino libraries (dependencies):
- https://github.com/arttupii/espNowFloodingMeshLibrary
- https://github.com/arttupii/ArduinoCommands
- https://github.com/arttupii/SimpleMqttLibrary
- https://github.com/kakopappa/arduino-esp8266-aes-lib (Only ESP2866)
Slave Node examples
- PIR-sensor node: https://github.com/arttupii/PirSensorNode
- Relay switch node: https://github.com/arttupii/mesh-relay
- Temperature sensor node: https://github.com/arttupii/mesh-dallas
Early demo video
Mesh usb adapter
Mesh slave node codes
- Esp32/Esp2866/Esp-01
- https://github.com/arttupii/EspNowUsb/tree/master/arduinoSlaveNode/main
MeshGateway software for RaspberryPi (conversation between mesh and mqtt broker)
Slave node code example
Slave node updates the button's state to topic device1/switch/led/value. The led state can be controlled with topic device1/switch/led/set on/off.
#include <EspNowFloodingMesh.h>
#include<SimpleMqtt.h>
/********NODE SETUP********/
#define ESP_NOW_CHANNEL 1
const char deviceName[] = "device1";
unsigned char secredKey[16] = {0x00, 0x11, 0x22, 0x33, 0x44, 0x55, 0x66, 0x77, 0x88, 0x99, 0xAA, 0xBB, 0xCC, 0xDD, 0xEE, 0xFF};
unsigned char iv[16] = {0xb2, 0x4b, 0xf2, 0xf7, 0x7a, 0xc5, 0xec, 0x0c, 0x5e, 0x1f, 0x4d, 0xc1, 0xae, 0x46, 0x5e, 0x75};
const int ttl = 3;
const int bsid = 0x112233;
add any messenger
tox, matrix, jabber etc.
