I completed the design and layout for the upright laser harp shield, and now I am working on the shield's CAD model. Here you can see how the ULH shield will stack on top of the Arduino Mega and Music Maker shield.
![](https://cdn.hackaday.io/images/3604121569912718625.png)
![](https://cdn.hackaday.io/images/5134291569912718756.png)
The following connectors are on the shield:
- Laser and photoresistor signals for corner one (7-pin JST)
- Laser and photoresistor signals for corner two (7-pin JST)
- Laser and photoresistor signals for corner three (7-pin JST)
- Laser and photoresistor signals for corner four (7-pin JST)
- Potentiometer (3-pin JST)
- Rotary encoder (5-pin JST)
- Photointerrupter (4-pin JST)
- Motor driver board (5-pin header)
![](https://cdn.hackaday.io/images/8370781569913348735.png)
Instead of the hundreds of cable connections required for prototype one, the second version will only have a few cables running through the box, making the electronics much cleaner and easier to assemble. The white boxes in the diagram below are JST connectors.
![](https://cdn.hackaday.io/images/4003121569913054647.png)
The first version (pictured below) is a lot of wire management! This challenge will go away in version 2.
