This super ICE Tower CPU Cooling Fan for Raspberry Pi is burned for solving heat dissipation problem!
Tower structure, 5mm copper tube, multi-layer heat sinks, 7 blades powerful fan, all the above combinations make this super radiator for Raspberry Pi 4B /3B+
1. Fixed the steel mounting fixer to radiator's heat dissipation cube with M2.0 screws
2. Fixed the steel mounting fixer to Raspberry Pi 3B+’s mounting hole with M2.5 copper stick, and please make sure the heat dissipation is contact to CPU shield properly.
3. Fixed the copper stick to Raspberry Pi with M2.5 nuts.
4. Connect the red wire to GPIO 5V pin and black wire to GPIO GND pin.
2
How to assemble it on Raspberry Pi 4B
Raspberry Pi 4B
2. Fixed the steel mounting fixer to Raspberry Pi 4B’s mounting hole with M2.5 copper stick, and please make sure the heat dissipation is contact to CPU shield properly.
