Thermochromic Temperature & Humidity Display
A 7-segment display using thermochromic liquid crystal sheets that are heated and cooled by peltier elements
In this project I built a two digit 7-segment display using copper plates that are covered with thermochromic sheets based on liquid crystals. Behind every copper plate sits a TEC element that controls the temperature and thereby changes the color of the liquid crystal sheet. The numbers show the temperature and humidity from a DHT22 sensor.
backplate.dxf
dxf file for the backplate
AutoCAD DXF - 45.22 kB - 08/17/2019 at 20:41
Download
prozent.dxf
dxf file for the dash shaped segment
AutoCAD DXF - 3.73 kB - 08/17/2019 at 20:41
Download
circle.dxf
dxf file for the dot shaped segment
AutoCAD DXF - 5.32 kB - 08/17/2019 at 20:41
Download
segments.dxf
dxf file for the segments showing the digits
AutoCAD DXF - 8.15 kB - 08/17/2019 at 20:41
Download
thermochromic temperature display wiring.pdf
Table documenting all the connections
Adobe Portable Document Format - 49.59 kB - 08/17/2019 at 20:39
Preview
View all 6 files
View all 13 components
  • 1
    Link to instructions
    Step by step instructions for this project can be found here.
View all instructions
