Triac based AC wave regulator
JPEG Image - 253.06 kB - 08/19/2019 at 11:40
JPEG Image - 287.04 kB - 08/19/2019 at 11:40
JPEG Image - 236.08 kB - 08/19/2019 at 11:40
JPEG Image - 92.26 kB - 08/18/2019 at 22:30
JPEG Image - 71.77 kB - 08/18/2019 at 22:30
View all 10 files
HiNice to meet you after viewing your profile i am Jacinda, from (jakarta) indonesia,
i have a project discussion with you please email me on: (jacinda.seiler@yahoo.com)
Regulator means that the input voltage can change without affecting the output. Is this the case here ?
No, the input voltage is the same as the output. This regulator changes only the width of the sine wave pulse.
Very creative use of old boxes. I like the one made from a broadband modem. Some of the others are works of art. You've given me an idea what to do with this old machinery control box in my junk^Wspares box. Thanks!
Thank you.
Good work, I'll be also inspired if you later share it here.
Blutorrent420
Christoph
Krzysztof Wrzalka
csdesign
Yes, delete it Cancel
You are about to report the project "220 Vac Power regulators", please tell us the reason.
Hi
