Now need to fix the dc pump in it hosing. In below picture we can see how we have fixed the dc pump. After this we need to connect the PCB circuit board with dc pump with soldering. In this step we need to make right connections means +ive with +ive and --ive with --ive side of pump motor and circuit board with soldering. Otherwise dc pump will work in revers mode.
