ESP-ACController
Open source project with ESP8266 that aims to control any air conditioner type
  • Description
  • Details
  • Files 0
  • Components 0
  • Logs 0
  • Instructions 0
  • Discussion 0
This is an open source project with ESP8266 that aims to control any air conditioner type over IR protocol using Android/iOS application or voice assistant like Google Home / Alexa.
How does it work ?
- When the device is powered on a webserver is started to setup WiFi connection.
- After that SSDP service is started.
- Mobile application find the device over SSDP protocol
- From the application you first have to init the device before using it with voice assitant in order for that to work mobile device and hardware unit should be at the same wifi network.
- After this process you can control your AC threw mobile application UI (you have to press a button to send a command) or the voice assitant (each voice action is command to AC)
